Alexis
F10 lci front end parts
Hi everyone
I’m new to the forum. I have a 2011 f10 5 series . It has been involved in a minor front accident , well I say minor as it was only going 15 mph but the wing and Bonnet crumbled , headlight smashed and also caught the bumper . Now I’m wondering about updating the front end to the 2013 onwards spec as most of it has to be replaced barring drivers side wing and headlight  . Does anyone know if this is all a straight fit ?
Any help would be much apprciated
Hello,
Is it an M Sport or SE? Standard halogen lights or xenons?
SE facelift has a newer design front bumper but im pretty sure the M Sport stayed the same. the headlight assembly must also fit in both as people have retrofitted LED headlights to pre-lci cars.
Edited by IINexusII
The change to the LCI M Sport was the position of the lower fog lights.  They moved from the centre of the lower grille to the outside edge.
16 hours ago, IINexusII said:
Hello,
Hi thanks for your help. Sorry mine is an M Sport with halogen , I know what I need to make the newer lights work  . Just not sure if I have to change anything for the newer M sport bumper to fit and whether the newer headlights will slot in and got in the existing brackets ? And also whether I need to change the front wings ? I know the bonnnet is different but that just looks a straight swap .
Thanks for your help
13 hours ago, bmwmike said:
Bad luck OP
Nothing to add other than be great if you took pictures doing the work!
Hi yes I will take before and after pics for sure. If it is a straight swap I may as well go ahead and do it .
cheers
47 minutes ago, Alexis said:
Is there anyone who has done this conversion?
I've not seen any posts here nor in the US where someone has changed a preLCI MSport bumper for a postLCI MSport bumper. It isn't really much of a conversion as the bumper covers look so similar. Realoem is showing a different part number for the cover only and the bumper carrier and other supports are identical so I'd assume the covers are interchangeable.
Hello there
I can’t find anything anywhere either , it’s just when i look up the parts for wings and the Bonnet , there’s an option for either 2010-2013 and then 2013-2016 so I’m assuming there is a difference .
Thanks for for your help
If required I have a spare pair of LCi M headlamp washer levers and caps I mistakenly got for my non-M F11.
Edited by HandyAndy_UK
14 hours ago, Alexis said:
Hello there
I've just done a side by side comparison of an LCI vs non-LCI F10 on REALOEM and the front wings and bonnet have identical part numbers. The bumper cover has a dfferent part number but as I said the LCI version MSport o e should be a straight swap.
Hi there
thanks I think I’m ok with them , if it turns out I’m not, I will let you know .
cheers
Ah ok , there’s a lot of confusing information over the internet about this , but part numbers don’t lie . Thanks for checking that out for us . Great help.
Cherrs
