cossie1
iPhone X and Intravee
Hi, I recently replaced my iPhone 7 (that worked perfectly with my intravee, using a 12v - 5v adaptor and an apple 30 pin - lightning cable) with the iPhone X.
However the iPhone X doesn't seem to work with the intravee (it charges when I plug it in), but I just get the message on the radio (bmw business cd player) in my E46 M3 saying No iPod (or maybe it's No iPod Adaptor).
Therefore I get no music playing through the stereo.
Just wondering if anyone else has the same problem or if my iPhone X is faulty ?
I have an iphone8 and i have noticed that it will show no ipod sometimes. I have to disconnect/reconnect a couple of times and also ensure the single song (Silent MP3) that's loaded onto the phone is playing. I have the latest IOS so not sure if that has anything to do with it.
Maybe it's time to use bluetooth as I have the Carphonics upgraded BM54.
This is what's happening to my iPhone 7 after the most recent apple software update. Have to plug in / unplug multiple times to get it to play music. Bummer
Ok so it's not iPhone X specific then, thats good to know.
Hopefully apple will fix it with an iOS update soon then.
In the meantime I will try connecting and disconnecting a few times to see if I can get it to work.
Thanks for the replies.
The exact same has happened to me, but I’ve noticed it’s not the phone. The phone stops charging after 20 secs which in turn then stops the music. If I keep the phone plugged in, and reboot the intravee from the headunit menu (Mk4) the phone starts charging again and music plays. 20 secs later it stops again. Can’t keep it going. I did notice the phone became really hot in the few attempts at rebooting the intravee.
Has anyone had any more luck?
right i'm running iphone 8 with latest developer beta version (11.2.5 beta version 15D5049a) and intravee firmware v6.02-7146, only issue is that when selecting intravee on source (CD) it all works but reverts back to sat nav screen on its own  after a few seconds if you dont do anything but still plays music fine.
I updated to 11.2.2 last night.
Just tried it again with the intravee, and it's a bit better, if I start the music first, then I can get it to work, sometimes on the 2nd or 3rd attempt (disconnect and reconnect the cable), whereas before I couldn't get it to work at all.
Switching back to the Nav screen is normal if you don't use the 'rectangles' button to toggle between the Audio and other displays.  So sounds like it's a problem Apple are aware of.
I have updated to 11.2.5 beta 6 (public beta version) and confirm there is no issue with using the intravee now.
Just plug the phone in and the charging and music work as it always has done (finally).
That’s handy, tried mine today running 11.2.1 and it was pretty hit & miss, will go to 11.2.2 for now and see if that helps
Intravee worked intermittently for a while with my iPhone x but since the last update I get nothing at all, not even charging.
Currently on IOS 11.3.1
Hi I seem to be getting this same issue. I plug my iPhone X in and it starts charging, and it will play music for a while (like 10 secs or so) then stop. It also stops charging at the same time. It’s almost like the system goes to sleep. I know its not my phone because I can play the music normally without the intravee, but obviously I want this to work in the car. Trouble is it doesn’t always happen, so I don’t know what the problem is. It’s happened since iPhone 7/8 era and has continued after getting iPhone X so maybe its a recent iOS thing, or the alpine kca-420 is on it’s way out, or the charge converter. It’s hard to diagnose. I’ve replaced the scosche charge adapter and still the same issue. I’m hoping someone has an answer.
