mac27040
BMW Z4 BOOT LOCKING
Hi Richard,
The issue:  Remote unlock the book, accidently put your keys in boot then close lid !!! happens to often. As the Z4 doesn't have a boot handle your stuck, also no access through from cabin.
Solution if possible: can the intravee send codes so when you unlock boot only it also unlocks central locking doors and delays locking central locking after boot is shut or you have to lock central locking via remote after boots shut.
I'm not sure if the Intravee will see the boot unlock, but it should see it open.
If the Intravee can unlock the car then it should be able to do this.  You can test this by seeing if auto unlock works.
