Misterbish
Your Thoughts On ECU Map Repository
Just want to know your thoughts on this.
i'm a Ducati nut and on a Ducati owners forum they have a repository for standard and performance ecu map's free for all to share, how would that go down on this site, i have a couple of tried and tested ecu maps that i would be willing to contribute if it would help anyone on here.
I currently have the following:
2006 E60 530D
Standard Map
Stage1 with EGR Delete
Stage 1 with EGR and DPF Delete
2007 E90 320D Msport
Standard Map
Stage 1 with EGR Delete
Edited by Misterbish
Quote
well, I'd be interested in the 530d stage 1 egr delete
I'm at work at the moment and the ecu map's are on my home pc, i will attach them later on this afternoon for you Dotcom
Quote
Do do remapping as a part time hobby i would be happy to do dpf deletes and egr deletes
No i paid for all my maps, when you say DPF and EGR deletes do you physically take them out of the map profile or do you just edit out the error codes so they wont trigger any check engine light
Quote
There's a lot of different software versions for the 520D (I assume you're talking about the 163BHP engine) though. Do you have access to them all?
Is the 320D and 520D the same?, as above i paid for these maps i dont have access to any other's
For example 320D - these are ones that read and write OBD. This is not counting software upgrades or hardware differences.
1037361858
1037372963
1037389882
1037387341
1037376967
1037379332
Thats by no means all. Just what I have at home not at work.
I do both one to remove the dtc codes and then also physically remove the map
Khile
If you have time can you look at the Stage 1 EGR and DPF off map when i post it, to check if they have been removed correctly from the map, i very happy with it but its wouldn't hurt to have a second opinion.
Hi
I'm using MPPS, i used 2 different people to mod my map files one for the 320D and one for the 530D, they didn't say anything was wrong with the file size, am i missing any crucial data with only a partial read.
MPPS explains it. Kess and CMD pull the full 2MB read out. It would just be worth making people aware that if this thread is OK with the forum mods, that you MUST put what tool read and wrote the ECU down with your files. If I stuck that in with a Kess clone (although in all fairness it probably would realise something was wrong and not continue to write - I use genuine Kess and Ktag for work but I do realise people won't be forking out thousands for these) and it went ahead and did it, it would turn the car into a paperweight until the ECU was recovered.
Out of curiosity, were you told that file would make 270BHP for the 530D?
Edited by Mashed Potatoes
I was told it was a estimated 270bhp, could tell the difference straight away so much torque, got a lot better once i had removed the DPF, also getting approx 5mpg more.
As stated above i have tried and tested this map, been on my car for 10 months now, pulls like a train, better fuel economy, no errors showing up, 8,000 miles covered so far.
Can't be happier
I'm no expert on the law but i cant see why not, i own the car the map came from, i gave the guy my original map which he modified, so it was never their's to begin with.
But i can see where you are going with this.
I suspect you don't have that right. I would think it's like bootlegging music or software. When I design buildings copyright remains with me. I grant licence to implement the design in a specific context I don't allow it to be replicated on other sites.
Think about it you paid for the map and then hand it out for free that's x number of customers the original mapper has lost.
If its it's your own map you wrote then that's fine though probably poor business sense!
My point is similar to Duncan's.
As a forum we don't condone the copying and distribution of licensed products similar to "dodgy" copies of BMW sat-nav discs.   Unless you can prove licensing of this distribution, we cannot allow it to be shared publicly on the forum.
to be fair unless stated in a contract which you must sign then the map would either fall under fair use or potentially copyrighted bmw but i dont see them chasing you down
Guest
This topic is now closed to further replies.
