Mazi
Oil Analysis
What is this oil analysis all about then??
Can it really tell me the state of my engine??
Engine oil analysis can be a basic indicator of engine health. It's not a new thing, this type of testing is common on very expensive machinery/engines used on big plant, and in aviation and naval engineering. Needless to say, it's not as definitive as disassembly and inspection of critical components subject to wear.
Completely co-incidentally I got the engine oil analysis results for my M5 from Miller Oils this morning!
The guys on the M5board seem pretty keen on engine oil analysis so I thought I'd give it a go. Was £25 - not much.
I noticed that the Blackstone oil analysis reports published on M5board have a column of 'Universal Averages' for our particular engines, so used this data set as a benchmark to make sense of my Miller Oil results.
Was a pleasing outcome for me since all the wear metrics for my engine/oil were better (some significantly better) than the Blackstone universal averages. The Miller report gives a load of info on the different metals/substances found in the oil. It's the amount of these in the oil (in PPM - parts per million) that indicate, to a lesser or greater degree, the amount of wear your engine has experienced recently. There's also other stuff about the general condition of the engine oil itself - changes in viscosity etc etc.. Wasn't particularly interested in that part of the report since I change the every year and have yet to do more than 5k miles between oil/filter changes.
How useful is the information to an owner? I guess if I saw that the copper and lead reading were very high then I might consider - as a pre-emptive  measure - rod bearing replacement even though the weren't yet making odd or alarming noises. I plan on getting my oil analysed every year from now on so I can monitor wear trends. Don't think it's going to tell me much about the chain guides though since they are plastic; a borescope inspection would be better for this, which isn't invasive or expensive.
An engine oil analysis report that reveals below average wear gives a little (qualified) peace of mind, I guess? (A copy of my report has gone into the M5's service history file.)
Here's a background piece I found useful:-  http://www.machinerylubrication.com/Read/30274/motor-oil-limits
Might want to wait a few thousand miles until testing the oil otherwise it's unlikely to give a meaningful result for accumulated wear metals. My oil had done 5250 miles when it was sampled and sent off to Miller Oil.
Wear-metal analysis, normally carried out by optical emission spectroscopy, gives you an indication of the rate of wear rather than the absolute state of an engine at any given point in time - ideally you would take a series of measurements over the over a service interval. Other features such as soot-loading or fuel dilution can also be measured quite easily, these are most applicable to Diesel engines.
its a rod bearing chewing unit
why wait for something major to happen
change your shells and you will have a good nights sleep
then its only the rust to worry about...... maybe the abs module!!!!
