Ram Rod
F11 jacking points
I m still keeping my options open regarding holding onto my 518d F11. It is already booked in for an intermediate oil change, but I want to raise the back to extend the suspension in order to clean the rubber gaiters of the shocks
The farmers in northern France ensure the roads are usually cacked  with mud, and the underneath needs a clean
I'm not sure what your question is?
If it's just to jack up remove a wheel, just use a trolley jack on the jack point with a suitable pad on the jack to protect the cars jacking point, take the wheel off and power wash everything. Put wheel back on and repeat on other wheels. I used to do that when I had time pre littl'un!
As @535i Andrew and @sshooie have said, get yourself a jackpad and trolley jack to raise each side, you don't need to take the wheel off, just reach in from the back of the wheel and wipe the air spring bellows clean.
Here is my jack pad, bought as a pair for a few pounds from eBay. I think they are made from hockey pucks.
my trolley jack has a large circular rubber pad which the above pad fits on top of nicely.
This isn't my jack but the pad design is similar.
https://www.machinemart.co.uk/p/clarke-ctj2qlp-2-tonne-quick-lift-low-profile/
