GoNz0
cableshack k+dcan owners, I have a question
I know Jimmy will be back soon but I am impatient. When you hook up his  k+dcan cable to INPA does it fake the battery detection, ie black dot on battery even when it isn't plugged into the car?
Thanks.
8 minutes ago, Mashed Potatoes said:
Mine works true to the ignition - not faked.
I am wondering about the battery detection, not ignition m8 :)
Both Batt and Ign come on with ignition, battery is detection from obd port which you can see from the led,
the only time you would need battery detection that I have come across is when doing smg reset using dis, it needs to see ignition off but battery on to finish job,
this is done by changing a setting in an ini file, I have only had to do this once in the 7 years I have been using these cables.
