On 17/03/2018 at 11:08 AM, duncan-uk said:
Prefer the other steering wheel if I'm honest which I had in my m3 but changed it for a later version anyway.
Looks a different car than from from the first pics though:D
Many People Do :D.. just I find it a better feeling steering wheel.. :D
On 19/03/2018 at 12:03 AM, 540v8 said:
Phone in console.... B)
Yeah... Just for show at the moment :D
On 19/03/2018 at 8:24 PM, Tuvoc said:
The first steering wheel is way better, in my view
Many people find the first steering wheel better I just like the thumb grips on the new one and the larger diameter steering wheel rim :D
Thanks For All The Comments
Update Twenty One
2/4/2018
Last week we stumbled onto a little bargain, and ended up with two new old stock Hella lenses.
For the grand total of £5:00.. Well I purchased the two lenses and a unopened e34 first aid box for £10:00,
we have also swapped the plates over from The Orient Express ( TUI1540 )... So she now has number plates to match her model.
Please excuse the dull side of the bonnet, I'm learning the skill of wet sanding and there was orange peel all over the bonnet.
So I thought it would be the perfect base to learn and lets face it, She will probably be getting a full respray within the next year.:ph34r:
All For Now
Comments Welcome
Edited by ustbutler
Update Twenty Two
24/4/2018
Been using Boudica more and more since the last update and she doe run lovely. But a problem, I've encountered is when the car is cold
she idles very lumpy but I'm putting this down to coil packs because, We've swapped then around and the other car run horrible with Boudicas coil's.
so those are going to need seeing to I'm looking into a performance company called Bavarian Autosport which make and sell performance coils .
So I'm looking into that company and product my thinking is if I need to replace parts and I can get a better performing part instead I'd rather upgrade.
Project Direction
I've also being thinking about project direction and what I want from the car,  What I want to do with the car knowing the
car will be around for a long... long time and finding a nice example made this a little daunting I've came to the decision I want a car
I can take to a car show and be happy and also do a couple of run what you brung Drag racing event's after I got the Drag Racing bug last year after
attending a Pistonhead's Sunday Service at Santa Pod Raceway with fellow forum member (Gareth Wood) and his 540i/6.
Boudica already has a limited slip differential from factory ...But thanks to Gareth who visited last year on my Birthday with a very special
Birthday gift for me which will  change the ratio of my standard differential to a much more hair raising 3:64 .. Gareth traveled many miles to
come and visit me on my Birthday and the first I new was when I could hear a snarling  M60B60 sound outside.
So come summer, The differential should be uninstalled and reconditioned. 3;65  ratio is recommend by DINAN  which is an american BMW tuning firm
I'm not concerned about not having the extra gear as the 5th gear in the automatics is taller then the sixth gear in the manual I'd be lying
if I said I wasn't  looking forward to experiencing the ratio in automatic form I've experienced it in manual form and its the best bang for bucks.
    540iA Ratio ¦ 540i/6 Ratio
     1st - 3.55 ¦ 1st - 4.227
  2nd - 2.24  ¦ 2nd 2.528
     3rd - 1.54 ¦ 3rd - 1.669
     4th - 1.00 ¦ 4th - 1.226
     5th - 0.79 ¦ 5th - 1.000
       6th - NA ¦ 6th - 0.828
Another thing on the list which is more impotent is a new exhaust system its never been at its best since we have had Boudica. But using her more
the exhaust is leaking rather bad so a new stainless steel system is top of the hit list at this moment I'm looking to recreate the original system
I'm loving how Boudica sounds at the moment, She crackles and pops it's lovely and I'm hoping I can recreate this with the new system. I know you gain next to no horse power and I know you can loose torque so as close to the original system but with stainless steel should work out the best way. I might add an H pipe because I've heard this helps keep the torque but I don't want to make a drone festival headache making system. But that's next on the hit list I know many people experience improved performance after installing a stainless steel exhaust and its true but in most cases its because of the weight lose. If I remember correctly the front section of the  exhaust on a 540i weights about 9KG.. The centre muffler weights 14KG and the rear muffler weighs 15KG removing all that and replacing with stainless steel could reduce weight by up to 25KGS or just under 4 Stone
All For Now
Comments Welcome
Edited by ustbutler
A properly made exhaust will actually gain you a few HP; the silencing is generally done well and you shouldn't get any drone at all
They'll also be able to make you a back-box with the sound you want and if too loud still, they'll open it up and add more silencing material until it's to your standard ;)
Personally I'd advise at least 2.25 to 2.5" piping and, if you can, get the manifold done too.
I'm tempted to do this on my 530i one day as I've had custom systems on every car bar the 3 BMWs I've owned. The best one I had made was via the lads at JP Exhausts in Macclesfield for my Integra DC5 that was running a K20/K24 engine with a JRSC; the system cost me just over £1k, but it was a lot of work too.
Otherwise all my systems have been done by Pipewerx in Ormskirk and they were brilliant also and tuned the back box to the sound I wanted
As dan1979 has said a well made exhaust will have a slight improvement. Mine is booked in for a new one tomorrow at Infinity Exhausts. I’ve had a few exhausts made by them on a few different vehicles from a track car to my daily. They can do what you want with looks and sound. On the track car I wanted a straight through but would struggle with noise limits so they fitted a small centre silencer to keep exhaust flow and reduce the noise. On my daily Octavia vRS you can hardly tell it has a nice exhaust driving it but once outside you can. Sure a good company will be able to do the same for you with keeping some of the noise you are after without the drone.
Didnt realise the exhausts weighed that much! Hoping to see similar weight savings on mine then.
I've heard that  manifolds for a M60s are changing hands for big bucks, I did wounder if am exhaust shop would make a manifold I asked one a  couple of years ago and they wouldn't undertake the job :sad:
After removing one they are so so heavy... You'd gain from the weight saving alone :D
Update Twenty Tree
21/5/2018
I can report another uneventful month and nothing much has been happening or happened, I have done one marmite modification
and fitted an ACS clock face to my instrument cluster I know I might get some ribbing for this but I think it looks retro cool.
:D
I thought It would be a good idea to do a Zero to Sixty test before fitting the lower ratio final drive and any other modifications to get a bit of
a baseline for future modifications so we can see what does what and what doesn't do what.
For your enjoyment and everyone else, and to keep everything in the real world I filmed the run to look back on in the future.
All For Now
Comments Welcome
( Especially On The 0-60 Time )
Update Twenty Four
15/6/2018
Well we have less then one month till BMW Show @ Santa Pod Raceway,  Normally we attend
BMW Show in the old fateful Orient Express its a much easier process.
Well this year we will be attending in our newest edition Boudica but this makes the process a lot more
difficult normally with the Orient express its a quick coat of Poorboy's Black Hole followed by  Poorboy's Natty Black wax
and we are ready to rock and roll but with Boudica its going to be a rather longer process.
The paint is alright for a car of its age but being outside half under a tree for many years has left its mark on some panels
with nothing to lose and maybe a little to gain I decided to do something drastic and wet sand a few panels to see what I could achieve.
The main panels that where playing hard ball were the drivers side back panel and door.. boot and bonnet so the task was set
and I started on the drivers side first.
The bonnet and boot are both flatted down and are waiting to be buffed back up again the results are not perfect
but a good 50% better then when I stated the whole process these are some photos of the boot before any work was undertaken.
And when we look back at the first photos posted we can see how dull the bonnet was after being in the aliments for many years.
On the maintenance side I have a clutch fan on order and a new belt which should arrive on Monday, The eagle eyed
would also have noticed the front bumper has been straighten out and along with the rear bumper has been treated to
a coat of satin black paint
All For Now
Comments Welcome
Edited by ustbutler
