2 hours ago, Blackman said:
Lovely colour and good that you're saving it, but the 540i definitely needs a manual box :) Have you managed to have a look at the sill panels/jacking points? Probably with the skirts on, you can't see much anyway...
The colour is what first attracted me..... She should be plenty of fun when the 3:64 LSD is fitted and some software has been tweaked.. But the manuals are the ultimate :wink:
1 hour ago, Carl-e34 said:
I will hold back judgement ... but the sills and jacking points do feel fine ... and the jacking points do work  :ph34r:
 If Stefan needs the manual rush  ... TBL is normally ready to rock n roll :D
Always willing to make you feel like Burt Reynold..
Just now, e34m525i said:
Awesome project I saw the car myself advertised and thought that should be saved!, well done for saving this!!!
Thanks and yeah she definitely needed saving..:D
Thanks For The Supportive Comments
Update Four
3/10/9/2017
Today saw us removing all the surface rust from where the fuel tank lives and applying a coat of red red oxide primer.
37449847242_e327ffc1b9_o.jpg22237057_10214296273658506_208624566_n
37222743110_b931114c8f_o.jpg22215282_10214296274258521_2112783496_n
23628511158_23ef7332bc_o.jpg22215209_10214296273578504_229338104_n
37222743680_e28c536a5d_o.jpg22215067_10214296273858511_105006035_n
23628511528_a75e4444a1_o.jpg22207393_10214296273938513_2027884016_n
After a few cups of Tea and five hours later it was ready for the trusted Hammerite.
37449978662_71864f67bc_o.jpg22215046_10214296274378524_2098201660_n
36771462524_85d22e485b_o.jpg22214986_10214296275218545_2005749465_n
37433121056_29b3fc31b7_o.jpg22207539_10214296275058541_1397758852_n
37222900920_962546f964_o.jpg22215093_10214296274498527_1819684454_n
37433119506_3b93807022_o.jpg22236343_10214296275098542_15207551_n
36771461724_36a61b1037_o.jpg22236487_10214296274658531_503762603_n
That's that part done the front and sides haven't been forgotten there just isn't anything to de-rust on one side and we are waiting for another nimble stone to arrive to attack the one patch on the other side but it will be addressed when we fit an detachable tow bar later this month.. ;)
Why we where waiting around for paint to dry..:lol: We decided to condition the leather again and come across the build sheet tucked away in the rear bench.
37450235622_e043dd6d5a_o.jpg22237372_10214296273138493_147603339_n
37480932951_f8522e8b40_o.jpg22207547_10214296273058491_1557197709_n
I took a quick photo and put it back where we found it.. That's all for now should be an exciting updated tomorrow.
37433368486_ff65d4e2ae_o.jpg22237358_10214296275338548_1858404013_n
Comments Welcome As Always. :D
Edited by ustbutler
Nice one Stefan! Already top notch work is starting to shine from Butler HQ! I've got a funny feeling that this Hammerite fetish runs in the family right? :lol: Keep up the great work and I'm sure you'll be rewarded with another fantastic 540i in the end. Such a worthy project and I wish you all the best in your build.
Regards Marc :)
Regards Marc :)
Thanks mate defiantly a labour of love but she isn't a hard car to work on if that makes sense some of ours have given us real fights :lol: But this one definitely wants back on the road .. We do like Hammerite :lol:....It works thought and hasn't put us wrong yet the local D.I.Y shop knows what we are after when we pop in :lol: I'm hoping she will be a lovely thing when shes done thanks again for the goodwill wishes. :D
Update Five
4/10/2017
First step was refitting the gear selector and surround which I'm happy went back together lovely as we didn't original remove it
but the previous owner took great care removing it so it went back together great.
37243093860_0cf0a5e026_o.jpg22237246_10214304255138038_1718078618_n
Then we went about changing the oil and oil filter and replace with Shell Helix oil and Mahle filter
36831378273_d38795bfe9_o.jpg22264707_10214304255098037_916661883_n
22236396_10214304292258966_58294546_n
Old oil and filter.
36831378903_72e4b57856_o.jpg22236572_10214304255058036_1568850238_n
37452639646_356978a2fe_o.jpg22264720_10214304254978034_395129163_n
I've never seen 15 year old oil before so I wasn't to sure about what to be expecting.
Then it was time to address the bull in the room and attempt to start the engine first task was to naturalise the pesky alarm.
luckily there is a long and lengthy process of resetting the alarm and that step was undertaken and the alarm is working again.
we then removed the fuel pump fuse and still nothing turns out our standby battery wasn't keeping charger so we swapped the battery
and she turned over on the button...we turned her over a couple of times to move all the oil around the engine we then replaced the fuel pump fuse and turned her over again after roughly three attempts she came to life we left her running and got her up to temperature checking for leaks and making sure everything was copacetic and as luck would have it everything seems to be in good order.
:D
( Click HERE For First Start Video )
That's All For Now
Edited by ustbutler
It's gotta be said guys that turned over a bit longer than I would have expected for it to fire up? I would have said you might have had a fuelling problem to begin with before it burst back into life? Unless that was the two first couple times you turned the engine over to get the oil pressure up before replacing the fuel pump fuse? I think that is what I understood above?
Either way congrats to you both as you can now successfully say you have another running E34 M60b40 in the family! :D Yeah! Nice one guys! :D Ahhh the sweet sound of success when the V8 finally fired up! :)
We do :lol:
1 hour ago, adam73bgt said:
Sounded like a long time to have it on the starter just to get oil round! But good that it got running in the end :)
Just now, Tuvoc said:
Compared to the video just above, Ford Escort barn find first start after 18 years, started almost instantly !
The first and second turn over was with no pump fuse the second time wasn't but she only had ten pound of fuel with the front of the car up and on a slant a fact we failed to pick up on once we added more fuel she started wasn't the quickest of starts but now shes on the button :lol:.. lazy old girl :wink: we haven't had much experience with starting engines that have been stood but managed to get her started so I'm striking that up as a win :lol:
Thanks For All The Comments.
Edited by ustbutler
Update Six
8/10/2017
It's all been plain sailing and a bit of a laugh until our first major problem  rear its ugly head upon the first test drive we noticed the gearbox
will not let us reverse... :ph34r: and neutral is like drive anyway when we got back and had a cup of tea... we tried to see what it could be ..  Upon arriving back at the car she had lost all gears..:mellow: fast forward to this morning  Sunday at Butler HQ is car wash day the neighbour comes out very inquisitive about old Boudica and it comes to the normal line of " whats she sound like "  so I started her up from out the car and she starts to move forward..  luckily Dad can still move when he wants to :lol:
So the long and short is we have a gearbox problem first we had no reverse and neutral was like drive then we had no gears now
all the gears are drive gears including park.
37319071850_601b0396ef_o.jpg22359131_10214336543745233_1230515506_n /url], on Flickr
On the bright side.. all the brake calipers are free and in good health
36907857233_cc52758fe3_o.jpg22331105_10214336543025215_1240340599_n
Dirty
37545596432_22fcb1d960_o.jpg22359490_10214336542305197_1192622039_n
Very Dirty
36907855493_41848b0cf6_o.jpg22407525_10214336541585179_338449758_n
Much cleaner and free brake nipples and pistons.
37545595452_9a56c7f021_o.jpg22385127_10214336541425175_739571490_n
37319070900_c6046efe5d_o.jpg22361086_10214336538545103_1103548828_n
Rear disc looked like they had just been changed prier to her coming off the road..:huh: Unfortunate I don't have any cleaned up photo's of the rears
but I'll be painting the calipers this coming week I can't stand rusty coloured calipers and lucky the rust hasn't attacked them so painting them with be a pleasure.
37577580431_40ddd0b3f3_o.jpg22361428_10214336538425100_449880982_n
Some of the old brake fluid we will bleed the brakes again when new disc..pads and shoes arrive.
37577980221_1824705c93_o.jpg22385205_10214336540585154_740806188_n
That's all for now :)
Edited by ustbutler
Wow that's an impressive collection of cobwebs right there! Enough to make the Addams family proud I rekon! :lol: Well, you guys are definitely making progress as it's moving under it's own stream!B) Re gearbox, almost sounds like the cable is not adjusted properly?! Too tight maybe?! I Where you able to manually select all the gears from the selector shaft before you fitted the new cable?!
Edited by boiliebasher
I've been under again ... and checked the cable adjustment . It sadly, looks to be working fine :ph34r:
 The cobwebs are home to some big and vicious spiders :lol: It's not nice being on your back looking at some p**** off Spider :lol:
Update Seven
14/10/2017
We have spoke to our local independent BMW specialist about the gearbox problem and she will be going in within the month
for investigation ..:rolleyes:  unfortunately we have no access to a ramp or pit so we thought it would be best to leave the job to someone that has experience
with these gearbox's and know what they are doing... Don't worry we still have many niggly jobs to undertake...:)
Window Wipers
Upon first inspection we noticed the window wipers where seized so today we set about liberating them.
First we had to remove the wipers and scuttle panels.
37440741400_4affcea3c8_o.jpg22472825_10214383761285642_1980243440_n
Like most of the car many spiders had made it home.. Their home..
37649687646_140bdcc728_o.jpg22500955_10214383761565649_67566678_n
37666116572_b43d2835d7_o.jpg22523617_10214383761805655_2072159280_n
37440736660_76f77ea7b1_o.jpg22523880_10214383761405645_1304443329_n
Before we could do any liberating we needed to do some cleaning..
37649687116_9ea9dde193_o.jpg22523703_10214383762405670_1897700033_n
37666118362_afed63a756_o.jpg22500840_10214383761925658_1981898700_n
37028618553_5cab2b8924_o.jpg22500706_10214384012811930_705257755_n
With all that grime gone we liberated the wipers plenty of SAS spray and a little bit of time.
We have moving wipers but only on the maximum settings and they aren't moving very fast.. :ph34r:..
We have changed the wiper module and Control Module..I'm hoping to see everything loosen up a little more tomorrow
We have left the spindles and arms soaking in SAS spray over night and we will see what tomorrow brings.
Edited by ustbutler
Update Eight
23/10/2017
There comes a time an E34 owner must do the dreaded..  sill cover removal and this weekend was our turn.
Again.. Remember the longer you put if off the worse it could be.. or couldn't be..
37631996330_df7f524bc0_o.jpg22782180_10214457162360623_1925019757_n
24036971868_c413462b81_o.jpg22773409_10214457162640630_1238907348_n
37888767011_1894aba609_o.jpg22834351_10214457162680631_776851132_n
24036970108_5e48d635bf_o.jpg22781996_10214457162280621_929352444_n
37888765721_58dc1d1c7d_o.jpg22834696_10214457162760633_243967340_n
I can't stress enough how important it is to clean behind the wing it will most probably put years onto your car.
All rust is wire brushed away with a wire attachment or stone attachment then soaked in rust converter just for peace of mind.
24036966398_cc8a5685df_o.jpg22811564_10214457162720632_364175830_n
37888766131_1f142124a3_o.jpg22834648_10214457163400649_1997007771_n
37169047033_c68481bbcd_o.jpg22773444_10214457163000639_218143275_n
37857756032_b64725e559_o.jpg22811404_10214457246802734_833284871_n
One small hole appeared about the size of a small cotton wool bud so we filled the hole with
rust proof and smeared some Corgo quick steel after another going over it was as good as new.. It's nice when you find no real horrors.
Red Oxide Time.
24036973028_6c5b825e11_o.jpg22752879_10214457164000664_773639574_n
24036975308_dd43792f43_o.jpg22752434_10214457163920662_2120182015_n
37631994540_6b7e86d64f_o.jpg22809915_10214457163640655_2016748984_n
Why the red oxide was setting we set about removing the wing and see what was lurking..
22782173_10214457164440675_1357659192_n
37169046063_578207719d_o.jpg22773667_10214457164520677_368839156_n
22752803_10214457164480676_25755952_n
37857756522_7c96bf1e92_o.jpg22811257_10214457164600679_1592842196_n
I seem to have not taken any photos of the cleaned up stage lucky the little bits cleared up great much like the sill
apart from a small cotton bud size hole which was treated the same way as before.
Red Oxide.
24036966768_1118ca2c33_o.jpg22811313_10214457165160693_380118831_n
24036974438_c5196d60c9_o.jpg22752671_10214457165080691_35343594_n
Final Stages.
37857764252_eceac5df6f_o.jpg22752262_10214457165720707_1113935840_n
37857763172_947609c65a_o.jpg22752758_10214457246602729_1621079403_n
24036970388_54910536d8_o.jpg22773486_10214457165440700_896349646_n
37857756812_037e2105d0_o.jpg22810019_10214457165600704_850055033_n
We also saved the bottom of the wing.
22834477_10214457246322722_2133844838_n
On a whole we are really happy with the first sill It could have been so much worse all the rust has been removed
then socked with rust converter for good measure then coated with red oxide and then Hammerite Hammered black.
24037837668_31232c28e9_o.jpg22752881_10214457166400724_171616742_n
All For Now
Edited by ustbutler
On 10/24/2017 at 7:21 AM, paperjams said:
It’s in very good shape!! You must be very happy!
Good shape all things considered.. We are very happy :D
On 10/24/2017 at 10:12 AM, d_a_n1979 said:
Such a great project to follow 8)
Thanks.. Such a nice project to work on to be fair :D
20 hours ago, boiliebasher said:
Looking better by the day great work guys ;)
Thanks :D
Update Nine
26/10/2017
37649687316_1184cbf349_o.jpg22501127_10214383761205640_965763064_nr
When we removed the wing ( to check the sills) we thought it would be a good time to change the drivers side spot light
37666118892_369591c28c_o.jpg22500682_10214383761005635_161083756_n
37440740850_92cef81322_o.jpg22497533_10214383760965634_1173012339_n
I'm sure the neighbours think we are dressing the car up for a Halloween prop
:ph34r:
37440740360_dc3a6f6c0b_o.jpg22497715_10214383759525598_917202454_n
37440736220_d52e2d59d6_o.jpg22523926_10214383759565599_179461624_n
Why the bumper and grill was off I painted the pipes..Which looks much better and cleaned all the leaves and cobwebs.. It could do with a wipe
down with some APC but I didn't have non at hand and I didn't fancy getting water all over the show and we could see rain would stop play..:mellow:
37920365762_1125c2a7e5_o.jpg22729151_10214478298049002_2383992723690299354_n
We quickly put everything back together before the rain came  The Silver Unit will be donating her
slam panel trim as its broken amazingly all the other under trays are still present and in good condition.
37666117542_d5930764a2_o.jpg22501084_10214383760125613_1322176799_n
37440734830_f92e23d27b_o.jpg22538057_10214383760085612_2015220472_n
All For Now
Edited by ustbutler
Update Ten
21/10/2017
38017919866_f99a3238de_o.jpg23114838_10214517374105879_864814884_n
Today was time to attack the front lower valance in the usual fashion.
38040206512_a0fe291908_o.jpg23163470_10214517373345860_390450422_n
38071225911_81313f63ae_o.jpg23113326_10214517374025877_187688183_n
26294993989_fe8e1d3474_o.jpg23113376_10214517373785871_1055730365_n
Red Oxide.
38071223031_d4665034cb_o.jpg23114768_10214517373025852_2030584831_n
38071222451_0d27687b24_o.jpg23114780_10214517373265858_1315491458_n
37361598454_2207422030_o.jpg23114756_10214517373225857_587382273_n
Hammerite Hammered Black.
37361597464_4f7aab4b0c_o.jpg23140453_10214517372305834_759988755_n
38071220611_a9385043a1_o.jpg23163600_10214517372585841_1816960256_n
38017918956_70f54c2954_o.jpg23163639_10214517372625842_1373356555_n
26294990179_2cdf3b739d_o.jpg23192566_10214517371985826_1862322755_n
This is always a nice rewarding one.. when doing the sills your hard work gets mostly covered up.. But when cleaning
the front valance your hard work always greets you upon crawling under the front of the car or at M.O.T time.
All For Now
Update Eleven
5/11/2017
Time for round TWO........
26419769459_2e9360f1fb_o.jpg23360778_10214557679233482_2134034039_n
24344059998_8077cd42c1_o.jpg23315821_10214557681433537_1262943583_n
24344057988_cd0a58f07c_o.jpg23364830_10214557684033602_356585619_n
38196752271_aae704a09d_o.jpg23364877_10214557678753470_1857059615_n
38140515316_a1258cd224_o.jpg23283322_10214557678713469_566210513_n
We expected this to be the worse sill out of the pair but once we got into cleaning the rust away it wasn't half as bad as we thought.
Unfortunately I only seem to have the finished photos from the jacking points but they did come out lovely and no horrors.
26419775889_50692be8c6_o.jpg23283322_10214557686553665_1259231921_n
26419774189_e14e0236c7_o.jpg23283330_10214557688313709_1808253774_n
Much better ..:)...:D  We noticed a little surface rust around the vent pipe ? And around the circle panel on the floor.
24344062458_cd5d64ebb8_o.jpg23283407_10214557684593616_1404698662_n
38164741832_53eded1030_o.jpg23283276_10214557685073628_2055959975_n
Finished result.
37486027114_ffe290194c_o.jpg23315769_10214557688793721_1566800074_n
38196754521_af7268265b_o.jpg23315974_10214557685793646_258041331_n
 Off with the wing.
38140970916_3b32668b1d_o.jpg23318797_10214557685993651_628503066_n
26419771879_106719aa53_o.jpg23315807_10214557685113629_1309668569_n
38196753401_075d0713b5_o.jpg23361028_10214557687793696_1594603024_n
38197528691_28634f7dcc_o.jpg23361151_10214558181246032_728993452_n
Finished product.
37486024734_861e5263d1_o.jpg23315884_10214557690553765_1292856117_n
All For Now
Edited by ustbutler
Update Twelve
7/11/2017
Power Steering fluid has been flushed and replaced..
37525903944_e44ba3ca70_o.jpg23435451_10214569714534357_1959695482_n[/url
 Much much better.. .. The window washer pump had also died a rusty death..
38237224891_c48d33ef48_o.jpg23414516_10214569714294351_745324981_n
New one in the box... :o.. No photos of it out the box.. :lol:
38237302591_fbe4221628_o.jpg23414356_10214569714334352_1499160335_n
All For Now
Edited by ustbutler
