Followers 0
BLITZ
M57TU2 running problems
5 posts in this topic
Hi I have a car here which starts fine and idles ok. Anything below 2K revs theres no power and is jerky but over 2.5-3K the power comes back on
Theres an EML light on with the following codes
003FF0 DDE - Air flow sensor
004587 4587 Fuel Filter
004501 DDE- Exhaust gas re-circulation, control deviation
Glow plug cylinder 1-6 activation
Is there any think I check first for?
If I clear it the EML comes on soon after with the same codes
Sticking EGR valve is a high possibility. It'll cause a bad MAF reading which may bring up that fault. I'd remove it and clean it then put it back on. Also check for vacuum at the end of the pipe that controls it. No vacuum will mean the valve will be stuck in a certain position.
Sorry for the delay. The EGR has was horrible and has been cleaned but it still have the same problem. But if you disconnect the vacuum pipe on the EGR is drives perfect which puts my suspicions on to the throttle actuator attached to it or the EGR vacuum pipe is connected incorrectly as a garage has carried out major engine work on it before. Or it could be some sort of pressure valve that connects to the EGR.
Does anyone have a diagram on the vacuum system?
Edited by BLITZ
Followers 0
