Style5
E28 mudflaps - anyone fitted them ?
3 hours ago, Style5 said:
i have all the fitting kit but the fronts are a nightmare - or am I missing something? Just how do they go ? Thanks
You have to take the 2 lower self tapping bolts out of the splash guard,and part of the bracket hooks up under neath and then bolts into the bolt holes normally with longer self tappers and a tube type spacer if my memory serves me right ,top hole in bracket goes to the other bolt hole up in the splash guard
4 hours ago, Taffy 1 said:
I haven't a clue mate but I'd love to know where you obtained them from.
Kind Regards, Taffy 1
Ebay Germany. They crop up from time to time. Just make sure they will post to England and accept PayPal unless your ok with bank transfers.  These were a new set ! Lucky find.
Hi, yes cheers for that. The instructions were rubbish and I sussed that screw could be the only thing to remove. Bit fiddly but the actual worst thing was putting on the spring loaded clips / clamps. Had to scrape away sealant from behind the arches to get the clamps on ! I have a weird car - one side seems to be heavier with sealant than the other. Ha ha. Had the same fitting the sunroof wind deflector. Thanks for your help - it was spot on
Hi Jez,
I have the fitting instructions pictures from a new set I had back in 1998 that I can scan in and send if you still need it.
Currently in a shipping container but I should get hands on by mid September.
Regards,
Mick
2 hours ago, Ordnator said:
Hi Jez,
Regards,
Mick
Hi Mick.
Thanks mate. I did suss it in the end. I had some old instructions that were a bit faded but made sense when I found the screw to pull out. Hope it's going wel for you mate.
Regards
Jez
