Followers 0
Steve540
Newbie.. rough cold idle
9 posts in this topic
Hi so i litteraly just joined the forum after a couple of years off searching on it i decided to make an account
Ive got a rough idle problem but ill introduce my 540 1st
Winter this year i sold my 520 and bought a 97 540 113k montreal blau auto
I couldn't afored a manual im only 20 lol
Anyway it wouldn't run up to temp so i put in a new tstat and discovered the old one was drilled out
Gave the car a good service and put a factory airbox in
So since the car had been running lean jn petrol (13mpg) i wonder what harm it has done to the engine. I clean the idel control valve which was blocked with carbon i guess thats due to the car running so lean on petrol
So on a cold start the car sounds awful. Throwing 5 miss fire codes also. However once its running for 2 or 3 mins if you restart her she starts with a nice rev and falls down to a smooth idle
Just got e38 parallels diamond cut and put onto the 540
How's the MAF? Have you tried running the car without it to see how it is and what codes are thrown, if any?
Are the cats ok, no rattles/signs of them collapsing etc?
Ive done the maf thing before but i didnt realy understand what i was doing. I remember having the car on, disconected the maf and the car stalled immediately. I will redo the test to see if anything has changed. There is a bad rattle blow out in the exhaust unless thats a dodgy cat??
I found this huge vac leak after i got the car... not sure if it should be blocked which it now is or if there is a pipe belonging to it
1 hour ago, Steve540 said:
Update i unplugged the maf and the car is running slightly smoother in cold
So confused lol
Well; ether give the MAF a good clean with specific MAF cleaner (don't use anything else); or, replace it with a genuine one (not a cheap eBay jobby) otherwise you'll soon be having issues again!
Replaced the ccv today despite breaking 1 little clip but its fine
Old one wasnt a pretty sight. It had a hard black residue on the orange sealant part
Anyway so far cold start up is alot smoother!! Not as smooth as warm but i think thats to be expected
The car now turns on without the MAF plugged in after a slight cough
Thanks for your help guys
One more thing
I have still to clean the maf but since the car now starts with it unplugged what does that mean?
Generally if the car won't start with the maf plugged in the maf is dead. Also worth checking the o2s as if it runs well cold but starts getting rough when warm, the o2 sensors only become active in closed loop and when cold it's open loop, so that could also be an issue?
 ^^ To add to the above, check the exhaust system as even a small leak before the o2 sensors can play holy f*ck with the mixture.
Nice socks by the way!! ;):)
Edited by NWJW
pink socks......
Haha i tried to hide my matching boxers :D
Mu exhaust system isnt great i think the cats are wrecked because the car ran cold for 2 years which ment it done 13mpg if u were lucky lol
Once i get the back box either removed or replaced with a magnaflow muffler i will investigate
Followers 0
