Davee61
BMW X5 20" alloys on e61
Hi all. Can anyone shed some light onto fitting the BMW X5 wheels onto e61. Wondering weather spacers are needed.
Wheels are fronts 10"and rears are 11".
keen to speak to anyone who has done this. Picture is if the wheels I may buy.
Thank you
I'll try and find out. Also the tyres are 40 mm tire wall. I'm thinking maybe they will be too big for the e61.
Ill find out the ofset. Does anybody know the guy with the black e61 these are fitted too?
thank you
Offset, IIRC, will be similar to the ones listed in the post I linked to above, you'll need fairly chunky bolt-on hubcentric spacers, their necessary longer bolts and probably tyres too narrow, so they'll need to be 'stretched'...
IMO, some things weren't meant to fit, so best left be... But each to their own ;)
I've found out these are 10j wilde front and 11j wide rear front et40 rear et37 they will fit its will be very tight your looking 35mm spacer upfront with at least 30 profile tyre and 20 to 25 rear spacer with 25 profile tyre but take this with pinch of salt as I've never fit these wheels but that is what I would use
