Piper
530d intermittently not starting IM THIS CLOSE TO BREAKING THE BLOODY THING
25 posts in this topic
Flipping cars!
Turn the key, all electrics work. But won't start.
Voltage fine.
Leave battery disconnected for a bit, reconnect and it may start but not all the time.
Thought it may be ignition switch so changed that but is still happening.
Any ideas folks?
Edited by Piper
Fuel pump on its way out?
Maybe. I've got a spare one so I'm gonna bung it on
NuckingFuts likes this
May the force be with you sir.
Piper likes this
Ignition switch maybe if it's not turning over or ews fault have you had it connected to a computer yet?
Sent from my SM-G930F using Tapatalk
So let me get this straight, the car cranks but doesn't start? or doesn't crank?
if it doesnt crank it could be the starter relay (internal to the EWS)
Pull the fag packet pocket down, pull the EWS out, pin out the two thick wires and put a 20A fuse between them... hey presto.
OR, could be the blow off terminal
Piper likes this
Just seeing that error message would it not relate to the on-key immobiliser system and it potentially not reading the key correctly?
This thread sounds interesting for example:
Edited by chicaneuk
Thank you for the heads up. Yeah I'll give it a try
http://www.bimmerfest.com/forums/showthread.php?t=536505
Or it could be just the relay inside EWS unit like YNP already suggested. With diagnostics like INPA you can see live status on EWS module if key is recognised and are there other factors that would prevent the starter activation (with that relay).
Thanks,
Do you know of a how to guide of how to do that. I have INPA
Choose EWS (immobiliser) module and in there status page.
Is that the page with EWS sync  and EWS reset?
1 minute ago, Clavurion said:
No. Aren't those on Activate page.
Actually yes they are
E39 -> Body -> Electronic immobilisation unit (EWS) -> Read Status -> Reading internal state
This will show if the key is recognised and engine ECU is freed. On the lower tabs it will show if something is preventing starter activation.
Piper likes this
Thank you
17 hours ago, The Flying Banana said:
is it an auto ...faulty inhibitor switch ?
There is no separate switch for this. P/N gear position info comes from EGS (auto gearbox) module.
