We need a new section under technical (Admin).
Stretch Belt - Removal & Installation
This is a fantastic tool which I added to my toolbox, no messing with clamping which you find with others.
Inner Tie Rods
FVEwM4i
The Bergen universal tie rod removal tool is a cheaper alternative where 1/2" torque wrench can be used to tighten the rod to spec.
images?q=tbn:ANd9GcSSXEUSDlOGocVU5GGBeVz
Ear Clamp Pliers
D0jeyww
Knipex 10 99 i220 (side clamping), however cheaper alternative pincers are available.
images?q=tbn:ANd9GcRPeY112U4iF5xtCBe7bH2
Tools, good idea ;).
My info meeds are more basic at the moment. What are the common eTorx sizes used on the E60?
Edit:  Moved more specific question to it's own thread named loose strut brace bolts?
Edited by DarkHorse
I had to remove my air con compressor, so undoing the bolts the belt naturally came off, i put the compressor back on at an angle and used the bolting up procedure to pull the belt back
I recently changed the heater water valve and purchased this kit to help me with the various types of hose clips you come across.
£25 for 9 pcs from amazon, I don't think I could have done the job without it.  https://www.amazon.co.uk/gp/product/B019Z98OL8/
Edited by Deviant
I know knipex are silly money, but what's the quality like?
For 25 quid with a blow mould case, you can't argue with it. They're not snap on, but how often will the diy mechanic use them?
5 stars from amazon reviews. :lol:
If you're on your drive/street on a sunday afternoon, passed the point of no return with your coolant drained, you'll be glad you have this kit. B)
Edited by Deviant
Here's a useful wrench to have which saves carrying 8 separate spanners around. It covers the all important 16mm & 18mm which is common fastner size with BMW.  8mm, 10mm, 12mm, 13mm and 16mm, 17mm, 18mm, 19mm.
Facom 64C.J2 - RRP from £38
Edited by jake13
23 hours ago, Deviant said:
I bought them from Machine Mart with their vat free promo code. £36.50 from Amazon.
Edited by jake13
I've got a set of 4 of them made by Bahco.. Totally amazing
1 hour ago, ger said:
Agree that the Lisle belt tool is a gem, it just works!
I got the crank tool (same as the Bergen tool here) in a timing kit on ebay for about £20, something similar to this:
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F232208113247
I took the chance that it would fit and it did :)
Yes, the simplicity of the Lisle tool is what makes it awesome. I looked at the timing kit for the M57TU but they don't include the crank tool (bit baffled, TDC not important?). In my heyday I would have knocked it out on the lathe :D
4 hours ago, duncan-uk said:
So are they double sided ratchets then?
so say 8/9 one end 10/11 the other as an example?
yep
5 hours ago, Blobby said:
Ta, I think the 3 set will do for the boot.
9 hours ago, jake13 said:
Totally agree, although their delivery is excellent, normally next day.
I didn't pay for them.. I stole work paid for them
Bagged these via cash convertors on Amazon, £99 brand new, £60 less than the average lowest price.
