Monkfish24
E39 1996 535i PA Soft connection possible?
Hello,
I've tried looking around and can't find any answer, I have just bought a 1996 535, it has had new clocks at some point and they have not been matched to the mileage of the vehicle. The tamper dot is on and the mileage records no where near what it should be reading. I know you can change the mileage settings with PA soft and the VIN as I have researched this extensively. I just can't find out if it is possible to connect before I buy the adaptor cable and waste my money.
The car does not have OBD but does have the 20 pin connector in the engine bay. I have PA soft fully working on my Win 10 laptop and have bought an OBD cable before I realised it doesn't have OBD. I have googled but found nothing so far so my question is, Can I connect to the vehicles modules before I go buying the cable? I really want to get rid of all the lights on the dash and get the mileage correct as I am actually on a limited mileage policy due to me working away so mileage is quite important apart from the fact that I want this all to look correct.
I have high level OBD and MID if that makes a difference.
Ues but there not cheap ones, if you have someone elses cable and not mine then you should be able to use the cheaper ones on ebay
as mine are wired for ignition detection.
