Followers 0
E39mad
E36 classic ipod connections
8 posts in this topic
I am after a device that will allow me to put the ipod in the boot of the E36 and connect via the 6CD changer which can allow use from the BMW head unit. I understand that the CD43 head unit may be required.
I think the Connects 2 uses the radio aerial so that's out.
Used to have an Intravee II system in the E39.
Presume it is down to the above or a DICE unit?
Thanks - that would be great.
Gotta get myself a CD43 head unit also.
so found 2 but i think the Connects 2 one is E39 based as it has flat pins..i am guessing yoru E36 has round pins..if you were handy you could solder the E36 plug on tho ..pics below
And here is the BMW iPod interface unit that seemiiingly shows text etc on your display ..it has teh classic iPod 20 pin connector
Thanks for posting up the picks.
Yep mine has the round pin connector to the CD changer.
How does the BMW produced one work and does it connect in the boot? Not seen one before and can't find any online info about them.
Much appreciated
on other end of that cablw is the round connector that ges into the radio socket on the pictured interface , the loom is a BMW one and supplosedly splices in easy ..i havent looked at back of mine since i got ot but its meant to be an easyjob
It connects at dash ( comes in a rubber protective sleeve ) and iPod cable to glovebox
Will try see if i can find any instructions but i think its probably along the lines you have just posted
Edited by The Flying Banana
E39mad likes this
Managed to buy a CD43 headunit - the sound is soooo much better than the std especially with the HK factory speakers. It was a bargain at under £100 but does have a Rover badge on it (at the moment)!! It doesn't connect to the 6CD unit so an ipod system in the boot is on the cards!
Followers 0
