Compatibility with E39 530D 2000
Hi Jimmy,
I've tried various cable solutions and software packages to read error codes on an E39 from 2000 with the 20 pin connector under the bonnet, no obd port in the cabin.
Only half of the modules can be read, I'm missing amongst others the EHC module and GM module. Others such as the radio and PDC can be read. This is with Carly, ISTA-D and INPA.
Does this sound like an issue with the car or an issue with the cable + software combination?
I'm happy to buy your package if you think it's a compatibility issue with the cable + software.
if your reading some of the modules you should be able to ream them all,
what cables are you using now? have you tried with dis?
