bmw535dlad
E60 M5 gearbox fit my e60 535d?
This might of already been covered on here but if I was to put hybrid turbos on my e60 535d I don't think the gearbox could take much more as I'm at 725nm already so would a M5 gearbox fit so I could go more power?
Any advise would be great!
6HP26 box is good for 600Nm, that's the design input torque according to TIS and ZF for my pre LCi E60.
The LCi boxes can take a bit more but it's like 50Nm more, nowhere near you are or wanting to be.
http://www.ukrtrans.biz/files/2010/08/ZF6HP26_Transmission.pdf
I think there would be so much coding and adapting involved it would be cheaper to buy M550d or M5 in the long run.. Even the latest 535d is no slouch and you could try and pick up a second hand one of them
That picture with a gearbox in bits would have me guessing which part goes where. I wouldn't mind having a revamped torque converter though, at times mine feels it slips too much
Edited by Blobby
21 hours ago, jake13 said:
The hardest job would be getting the tranny off the car, rebuild is not too difficult because there are plenty of videos online.
ZF Repair Manual.pdf
Well that looks like a peace of piss, where's me adjustable spanner :D
47 minutes ago, jake13 said:
If I look hard enough, I'll probably find the 6hp28 repair manual.
I don't think it will be any easier..
Not difficult at all if you have all the necessary drifts and means to press down the spring plates when reassembling the clutch packs. And the accurate means of measuring everything.
Now I'm sure I've got a gift voucher from Halfords somewhere.....
I have stripped manual boxes down before so maybe i would be able to strip one of these, but because you need the special tools and not make do with something else, also the tolerances required and the possibilities of what can go wrong, i won't bother
Be nice to be able to pick up a box from a scrappy and get it on the bench at home. Could then strip and build at your own leisure when time and funds permit. Then do a swap for your box.
