Tims
Breaking E53 X5 4.6IS '02 Estoril Blue
 Apart from its' "little" knock, a very straight and well optioned car, with the added bonus of a 4.6 with only 117,000 on the clock
 We have what I can only describe as a list of toy's as long as your arm:-
Tyre pressure Control
Body Kit
Titan Shadow interior trim
Roof Rails
Rear door blinds
Auto dip mirror's
Electric adjust rear seat's
Pdc
Proffesional Nav
Motorola phone
6 Cd Changer
Dsp HiFi
Sunshade Glazing
Battery Master Switch
Self Level Suspension
Sport's Suspension setting's
Multifunction steering wheel, sports
Rear side airbags
Boot net
Electric, memory, sport's seats, with lumbar and heated
Headlight cleaning system
Rain sensor
Xenon light
Air con
Black headlining
Clear indicator's
 This is a very well looked after car, with one corporate owner and only 117,000 miles on it
 Located Junction 16 off the M1
All item's available for pick up or via courier/pallet
Edited by Tims
further to the above, can you give price for these?
1)    Rear door blind
2)    Rear 4.6 is diffuser
3)    Folding side mirror with switch
4)    Wheels
5)    Complete 4.6 is wheel arch
6)    Electric adjust rear seat with complete switch
On 05/02/2017 at 5:24 PM, Carlosos said:
Ohh might be interested in the gauge cluster. How much?
100 for that
On 06/02/2017 at 2:04 AM, john_ate said:
Hello mate. Price for rear door blinds including all associated stuffs for retroffitting (including the top bits and rear doorcards)
 The complete retrofit kit will be 400
On 5 February 2017 at 18:47, sayanthan said:
Wonder if the engine / gearbox ?ecu will drop into an e39 540
Sent from my iPhone using Tapatalk Pro
On 5 February 2017 at 18:50, sayanthan said:
....or maybe just the cams?
On 5 February 2017 at 18:55, dan101smith said:
Engine will - it's an Alpina B10 lump. Wouldn't think the ECU is much different, if at all.
The main part of the engine is based on the facelifted Alpina B10 V8 engine with single vanos. You would need to change the entire sump and the oil pump pick up, and oil pump chain. Changing the oil pump chain means removing the timing chain so you might as well change that as well as the guides as well, especially at over 100k mileage on any M62 engine. The ECU and engine map is mildly detuned (335bhp? IIRC) from the 347bhp Alpina map as the Alpina engine had polished and ported cylinder heads. The cams and crankshaft should be the same. Just swapping the crank over will give you an M62B45 (4.5 litre) engine.
HTH
6 hours ago, Dannyk21 said:
How much for rear wide arch flares
 Those have been sold
If the gauges don't sell to Carlosos I'll take them please.
Edit: I've looked online and people appear to fit these to e39 540's. I'll need to research if these will work on a 1999 535i.
Edited by stu08
On 05/01/2019 at 17:09, e34m525i said:
Are the gauges still available?
Yep 70 quid
I messaged him toward the back end of last year and that was received well.
If you have an issue, can you raise it with the team so we can investigate.
16 hours ago, e34m525i said:
I’ve tried messaging Tim’s but every time I do it says he can’t receive messages for some reason? Maybe a forum glitch?
 I have just cleared a couple of messages out.
 Also, I have got myself mixed up, the cluster I have is from the black X5 I am breaking, not this one
Is that still an is one?
 Yeah the black 4.4 still has it gauges in it
