sayanthan
Hypothetical alpina 4.6 question
I was browsing for an e39 sport front bumper for my e39 540 touring and came across a few used Alpina front bumpers and also a used 4.6 engine which on asking the breaker was mated to a 5HP24 gearbox , same one as in mine car. He has the ecu keys immobiliser etc. also seen a few sets of wheels.
4 questions:-
- Is this a straight forward drop in? Will I need to upgrade the radiator/cooling system?
- are mounting points the same?
- is the steering box in the b10 v8 the same as the 540? Not sure if there are any clearance issues?
- I'm buying some m5 Russ fellows headers and cats which should bolt onto a 540...will they also bolt onto a 4.6?
Sent from my iPhone using Tapatalk Pro
It's the same block afaik so yes it should drop straight in and take the headers too. I believe the alpina is a breathed. 540 anyway. Don't imagine they changed cooling system.
Steering box is standard 540 and only difference on the cooling system is Alpina specc'ed the tropical rad which flows a bit more coolant.
bit if thread hogging here Duncan plus four lots of phone costs  :blink:
On ‎09‎/‎01‎/‎2017 at 9:37 AM, duncan-uk said:
Yes it'll drop right in, you'll have to change the sump over though as the E53 sump differs to the E39.
I looked at doing the swap when I had my 540i/6, but couldn't find a 4.6 lump for reasonable money at all.
