firestorm999
E39 m5 anti roll bar upgrade?
22 posts in this topic
Does anyone do a front and rear upgrade kit that actually fits?
I've heard the eibach front is for a 540 and doesn't fit properly?
Also dinan don't do front anymore just rear?
I have a square setup 9.5j all round so recommended I do both not just rear.
I have adjustable anti roll bar links so that can help abit
Sent from my SM-J320FN using Tapatalk
My M5 came with a front/rear eibach ARB installed, part number for the kit looks to be 2054.320 from a quick search.  The only other part number listed for it seems to be for 6 cylinder models.
There's no fitment issues on mine and the bushes sit correctly in the mounts.  I can get a part number off the front ARB this weekend if needed?
I have the Eibach bars too,fitted the rear on it's own but removed it as i didn't like it, might be better when I fit the front as well, as far as I'm aware there is a bolt you have to grind the corner off for clearance but I have not done the job myself yet so it's still hearsay.
Did you manage to check dude?
Sorry for the delay, did this tonight.  Sorry for the rubbish night time pic, can make it out here.
2054.320
Yes can't see any apparent fitment issues.  You have to lower the subframe on the front I believe to fit it. Looks like the original arb brackets are used too.
Yes from looking online this comes with bushes in the kit. Couldn't 100% confirm though. I've read they're red poly bushes that are supplied.
It would appear a tab needs grinding on the Subframe to make the bar fit.
Sent from my HTC One_M8 using Tapatalk
Ah did you get that fitted in the end? Didn't know any modification was required
Just in the living room lol it just hits the Subframe so I'm gonna need to modify the Subframe a little. Nothing major tho
This is getting weird. Will report back soon as subframe is bolted up just doing the lower arms is a PITA with the bigger bar and powder coated subframe
Sorted it's bolted up now without the need to grind anything even tho I started to grind (dipshit)
It's very very close to the lower arm bolts, 1mm clearance Max......
I powdercoated my subframe with impact primer and the powercoat and everything was extra thick so made fitting a ball ache I will get some pics.
I had Kelleners front and rear anti-roll bars fitted on my old e39 M5 which were made by Eibach.
I had mine fitted at Kelleners on a Ring trip so no fitment issues.
cheers
