E12 fanatic
1980 528i sometimes runs sometimes not
I am going crazy trying to figure out what is wrong with my bmw. It will run great for hours and then nothing or it will start and stop immediately.
Hmm, intermittent problems are annoying, I think you need to identify whether it is an electrical issue or fuel problem:
I am not sure if the 528i is L jet? or if it has points & condenser, if it is L jet it could be the ignition control unit or coil breaking down, or if points and condenser just replace them anyway as they are cheap.
If it is fuel related, I would try the fuel pump relay (on the side of the fuse box) or the fuel pump itself, when it stops, try removing the fuel supply pipe from the back of the fuel rail (Bulkhead end) see if fuel is pumping into a jar (container) when you crank the engine.
I don't know what it's like for spare where you are, but if the above fails I would try to plug in a replacement ECU (If it is an L jet car).
Please bear in mind that these are things that I would try first.
Good luck & welcome to the forum.
Thanks for your reply. So it doesn't have points pretty sure it's transiterized  ignition also pumpING fuel plenty. I just noticed that the TDC  sensor  has been cut and where the plug was is no longer there I do not know how to wire this back in and can't find any diagrams that show. Thanks again for your help.
5 hours ago, Sir Anthony Regents-Park said:
The part number for a new pulse generator (the bit with the copper coil windings) is 12111273287, about $150 from BMW.
Thanks for your reply I tried to get the pulse gejara tor out but I could get it to budge. Also is there a way other then continuity to see if it is working or not.
