goosiegander
E34 535i Sport
Hi All,
As some of you are already aware I recently took delivery of a 535i Sport Auto in Diamond Schwartz with some nice options
Unfortunately at some point in the past the electric leather was swapped out for manual but no matter, Steven still has the Liquidken grey Memory leather which will be recoloured and reconditioned to suit.
So some pictures of the last decade of grime and vegetation.
Which was tackled in the usual manner...
Leaving this...
Placed a battery on and the engine cranks over just fine, decanted the interior and boot, had a cursory scrub/hoover and took stock of what’s missing and in need of attention.
So the jobs list I can see so far:
Purchase:
Source B35 Air flow meter
Source steering column surround
Source 95aH Battery
Source front sill section repair panel drivers side and jacking reinforcement
Source Manual conversion kit – Tims to the rescue!
Order Front bumper tow eye cover – Ordered
Replace front Screen
Replace headlining
Replace Door body seals
Replace dash – Slightly warped...
Servicing:
Inspect Engine valve clearances
Inspect Engine compression values
Inspect oil spray bar and clean
Change oil, flush and replace
Add coolant to system and bleed
Free off sunroof track cables and lubricate – remove headlining and heat gun the tubes???
Inspect Aircon system- this was converted to R134a in the past but no doubt at least some of the seals are now shot after a decade of inactivity...
Function test Fuel pump and supply, replace or flush through fuel system
All input welcome :D
I'm looking forward to this one.
A couple on your list match my own.
Will you do the entire list yourself?  ie manual conversion, welding....
Great looking machine after a good scrub but I would say that. Liking the Black Dash & Door Tops against the Parchment leather too.
What's the plan, restore and keep or are you moving it on? Needs some early Sport 415's for the full monty look. ;)
C.
Fantastic. I love how all these are starting to come out of the woodwork now.
Very similar car to mine. I converted to manual about 4 years ago, please get in touch if you want to pick my brain. There are a couple of oddities that I never got round to sorting at the time (reverse lights, dash errors) that I've since done a lot of research into. I also fitted a solid flywheel / clutch combo mongrel of E12/28 parts that works nicely.
Also, and unrelated, I can never get snow foam to work very well - to the point where I can't believe it can work as well as you have just demonstrated. I have a 105Bar Nilfisk machine, the proper brass adjustable lance thing (expensive) and the Valet Pro goop that everyone seems to say is the right stuff. It just never seems to lift any dirt. What am I doing wrong?
Casual thread hijack. :)
Hi Tom,
Valet pro foam is ok I guess, I'm using Dodo juice apple foam and find it to be very good at the correct dilution,
are you getting a reasonable 'cling' of foam on the car? if not adjust your lance accordingly.
Remember to allow a dwell time of about 10 minutes depending on the environmental conditions and if you don't get the result you want the first time simply repeat the process as many times as you need.
the 535 had three and in some areas 4 applications of foam followed by rinsing before contact washing
Hey!
I'm planning on doing some welding and the manual conversion if poss, its more about being able to get under and around the car so will need a ramp ideally...
22 hours ago, goosiegander said:
Hi Tom,
Thanks for that. It looks like foam (very thick) and it clings pretty well straight out the gun, although it's all gone after 10 minutes. I usually wash it off before that though because I don't like the idea of it drying on. Never tried more than one application. I'll have a play with dilution rates. Strangely the forum won't let me upload a picture, mine looks thicker than yours, but also sloppier. (Waay.)
If you need a lift and are lacking in excess floor space / ceiling height, have you seen these?
26 minutes ago, Blackman said:
Loving this. Where did you get the sills repaired? And how much did it cost, if you mind sharing?
I need to get mine sorted, would be good to know a decent place...
Still waiting on the invoice
its Spot on Tuning in Eye, there is a FB page :)
