p3tchy
P3tchy E60 Build Thread (IMAGE HEAVY)
Thought I would collate all the bits I have done into one, makes for easier viewing.
So I started with a 525d M Sport with more than a few issues. That's ok I enjoy a challenge.
1) idrive rebooting (didn't know a thing about these cars so went in blind) Fixed
2) Due to idrive not working, It was masking a host of other errors. Unable to reset service indicators/brake warnings. Fixed
3) mileage had been tampered with (maniplutaion dot) Found out the dash has been changed and the odometer was put as near as dam it, Not the car been clocked. Fixed
4) Ambient temp sensor shows -40 all the time. Sensor/plug/loom all checked. Last thing it could be is the dash. OnGoing (need to swap dash out or speak to the wizrd that is Enda.
5) Wiring messed around with under both seats Airbag lights on. Fixed
6) poor remote/radio (the Div amp was unclipped at one end) Fixed
7) Passenger door switch not working Fixed
8) Glow module and plugs not working, Showed as a stored code. Module and plugs changed (twice now) Fixed
9) Gearbox sump leaking Fixed
10) Poor perfomance/Pickup Fixed
11) Battery drain (weak battery) Fixed
12) Cracked Manifold Fixed
13) DPF blocked Fixed
14) Cat flexi broken Fixed
The rest has been cosmetic and bolt on's
Led Number plate lights and private plate went on.
Space saver purchased
Wiring to front bumper repaired
LED Halo's fitted
MV2's fitted to replace the Style 128's
20" Style 312's purchased as well
Restored my headlights
Glow plug's and Module changed, EGR cleaned.
Carbon wrapping started
Battery replaced to cure Transmission error and limp mode. (that's the old one, Nice Bosch S5 in there now)
Gen 5 (CSL) Spoiler arrived for boot spoiler project.
19" M6 style wheels purchased
Manifold replaced due to crack
De-cat and DPF delete purchased
LED reverse lights fitted
M Colour Grill
19" M6 style wheels fitted after being refurbed in BMW ferric grey
Final piece of trim wrapped
Glow controller replaced again (under warranty) Also VAC pipes and inlet seals.
20" Zito's purchased
And fitted
Headlight set number 2 restored
Sanded
Finished
Back brakes done, also painted the wheel bolts
How she sits (08/05/16)
Edited by p3tchy
1 hour ago, JohnP said:
Very impressive!
Cheers, DPF removal, remap LCi rear lights soon.
Then more preventative maintenance. All 4 front arms, Drop links, ARB bushes and tie rods this week. New shockers shortly after.
So I think I might have found the reason my car was down on power. No wonder the cat flexi was blowing, the exhaust gases had no where to go...
The internals of the DPF
Edited by p3tchy
looks mint, keep up the hard work. That DPF looks horrific although I don't actually know what they are suppose to look like inside so can't really compare
1 hour ago, donnylad said:
would love to do my lights, but would shit myself they wouldnt clear back up after being sanded!!
will they stay clear for long?
Should do for the life of the headlight. As it's the same lacquer that protects the paint, you can polish it, clay it, wax it etc.
I was a little worried before doing my last set but I went down in grade of paper a lot more, it took a lot longer and didn't look nearly as good. See here
3 minutes ago, HABS said:
looking great :) loving the lighting upgrade and the headlights have come out great
LCi rear lights going on this week, LED indicators to follow.
Boot lid should be done soon too. Told the painter not to rush, now I want it back.
all worth it at the end
cant bot wait to start modding
spent £££ on my astra but it was worth doing the time I had it.
Exciting but the Mrs will be on my back soon , telling me to stop haha
Edited by HABS
Exactly the same, Parts get delivered to work.
10mm Wheel spacers front and rear, Now the wheels sit like they should do.
Also since disconnecting my BT module, the TV has started working. Not even sure why I tried it but now need to code VIM.
Front
Rear
Updated the original post as I realized I hadn't listed the issues.
Had it Mapped, Now pulls like a train. No idea on the output but it's a million times better and more driveable.
Fixed a water leak. Turned out to be a pin prick hole in the Oil filter heat exchange. Thought it was the outlet from the head and also broke it so lucky I had a new one ready to go on. I was going to replace the heat exchange but a tiny bit of chemical metal has fixed that.
Fitted the F10 style Grills
