E28 Bert
What have you done on your E28 this week........
16 hours ago, Panda said:
Solved the issue of chasing my lamp switches from inside the dash and got a new dash piece from BMW
Got a new/used passenger mirror, acquired a new bootlid with m spoiler
And about to raid eBay so prepare for some progress
Hey fella
I need that dash piece - how much did the stealers charge for it mate?
Hey fella
It's £30ish mate
Not technically all this week, and due to time constraints I've done very little of this myself, however recent work includes:
- Fitting powdercoated rear beam with new subframe bushes
- Replace hard brake and fuel lines
- Replace OSF hard brake line
- Replace fuel pump, filter and bracket with new
- Fit powdercoated E34 M5 rear trailing arms, with new bushes, bearings, brake backing plates, ABS sensors
- Fit powdercoated front struts with new springs, top mounts, bearings, brake backing plates, ABS sensors
- Fit new brake rubber hoses front & rear
- Fit new front upper and lower control arms
- Fit new ARB drop links front and rear
- Fit new prop centre bearing and guibo
- Fit refurbished brake calipers front and rear
- Fit new discs and pads front and rear
- 5x new tyres
- Fit new rear Shadowline tail lights
- Fit new complete headlamp units, with new washer motors
- Replace dodgy headlamp plug on loom
- Replace headlamp wash/wipe loom
- Replace gearbox & diff oil
- Align bonnet correctly
- Fit Momo Prototipo steering wheel and boss
- MOT
Next job: drive the sodding thing!
2 hours ago, jeroen524td said:
Thanks for the invite Mick, but I'm at sea the 27th.
Hey jeroen,
No problem.  Where about are you at sea?
Wishing you fair winds and following seas.
Regards,
mick
Fitted aforementioned trim and a replacement non raggedy b pillar trim.
Currently 3 hours deep into removing the pinstripes and glue
Smug!!!
Had to replace crank sensors yesterday and put it off all day.
Got all the tools out, drill, drifts, Torch etc and settled down for a long afternoon.
Much to my amazement I undid them and they both came straight out. It literally took longer to jack the car up lol.
527 manual, sloppy gear selector.
Having converted my eta to manual, not too impressed with the very sloppy gears. Added new cup, a bush and pin clip thingy and still dreadful. Found that the shift rod joint had a lot of play. Once removed clearly worn and ovalled. Replacement from dealer was surprisingly not much better. So, visited a local machine shop, two small bronze bushes for £4 later and a little fettling and play has gone, much nicer, reverse is no longer in the passenger's lap !
Managed to get round to lowering it.
Got a mountain of parts here to fit too m5 spoiler, some bbs, new front valence, new/used bootlid, new/used mint bonnet, new chrome screen trims, various clips and gaskets. Awaiting on funds and a painter at present.
Also quickly fitted my e28goodies knob and gaiter
And just fitted a new viscous to the m20b25
Zobelbraun Eta had a second hand green rear windscreen and a new front green windscreen with a green top tint band fitted today.
Regards,
Mick
We had an 80,s day out, and it was dam hot!! it was so hot you could have done some crash pot cooking in your pants :blink:
Dunc B7s as in E28 B7 ?
Pretty much got rid of the last my last e28 bits
Have literally two or three bits left now.
Just uming an ahhing about selling off the manuals and sales literature.
