F10 530d
Yeah that sounds about right.. a clueless service advisor! Especially at BMW. Enjoy the weekend away.. ;)
Edit Jan 6th just started my car for the first time this year lol
Edited by bmwmike
Cleared the frost from my windows this morning. I noticed that the tinted windows had a thin ayer of frost and the untainted windows a thicker layer.
I'm guessing that the darker windows absorb more heat so stay slightly warmer than the fully transparent ones. Am I on the right track?
Certainly sounds a plausible theory.
I'd say so, taking longer to cool and retaining more heat for the frost to take hold.
Went to see another F10 M5 having spent the week deciding which would be the best investment of my time and most likely to buy. Waste of time. Min disc thickness is 22.4, these measured 22.45 therefore the dealer won't replace them. Back tyres on 3.2mm, again AUC standard is 3mm so they won't replace them. O and I've forgotten the most important part of my experience today, the sales person had clearly been out last night as even at 1pm, he absolutely stunk of booze, was clearly struggling and wasn't in my opinion fit to be at work (didn't see the point in complaining as his boss was clearly knew he had been on a night out but they where short staffed so i'm guessing that's why he wasn't sent home). Didn't discuss figures as the car barely meets AUC standards and wasn't the one for me.
Might have to pause the F10 M5 plans and just buy another F10 for the time being :(
32 minutes ago, 535i Andrew said:
Minus 9.5 deg C this morning, saw it rise to a tropical minus 9!
Atleast the door was frozen shut this time!
Heated seats & steering wheel a must :D. More importantly, keep that battery fully charged.
-6 here, I never thought a heated wheel would interest me, but the Mrs Golf has one and I must say I now sit in her car rather than mine on the morning defrost session.
Read all 14 pages of the soggy carpet thread then went to check mine; thankfully dry. I've located the offending covered panel and the 4 x T30s.
I changed to a  low mileage, young car to avoid this sort of thing but it seems obvious now that I must remove the cover, clean and dremel/file in a drain. I will curse and cuss the whole time but probably not as much as if I have to argue with BMW about why the AUC warranty should cover it :o
It lives outside, partly under a tree so it's definitely a ticking time bomb. Even so, it's a job for a (much) warmer day ... ;)
For the first time in nearly two years of ownership the heated seat was at heat position 2 rather than just the single lowest setting.
I got a Ctek charger for Christmas, not used it yet.
You certainly will curse!!!. If not for the sudden loss of skin on your fingers and hands, it will be getting the cover back on and trying to line it up with the various slots, hozes and screws!!! Good luck. Have a really good feel around where the top of the cover slots into the rubber seal around the two heating pipes. It will feel wrong if it is wrong.
Edited by nashdm2
Just dropped mine off for its MOT.
Normally I would now spend all day stressing that my car is in for an MOT while endlessly refreshing the MOT history page on the .gov website.
BUT, the very smiley customer advisor pointed out that as my car is still under the 5 year 60,000 mile service inclusive pack, just, this includes a 24 month MOT protection which starts the day the car is 3 years old, so if it fails on anything today from a bulb to a coil spring, I'm covered.
I didnt know about about the two year MOT protection being part of the service pack. Brucey Bonus.
And also local dealer is having a special deal on MOTs in Jan for a price of £34 instead of £54! Double Brucey Bonus!
To the original owner, I thank you again for spending your money on something I'm benefitting from!
:D
Well  according to .gov it failed then immediately passed.
It failed on both headlights aim being too high.
The tech must have failed it then adjusted it and passed it.
The headlight aim is automatically self adjusted on cars with adaptive Xenons isn't?
It sure is. So I wonder what the tech did, fiddle with a setting in ISTA?
Thanks Matthew.
I was on the other phone when the dealer called me.  The voicemail just said it was ready for colelction and no mention of anything else.
I will ask how they adjusted the headlight aim.
I might also ask them how they tested my towbar too and watch them squirm!
On 09/01/2018 at 11:15 AM, Retset said:
So some nitrile gloves and long sleeves for this one then! Should reduce the bad language quotient a little!
Mines still off awaiting much nicer weather!
Thanks Matthew.
I think the towbar is a bit of a grey area. Unless it is visible to the tester i.e. in its fully extended mode, they don't go fiddling to get it out in order to check the electrics.
The implication is that they should test it, even to the point of fitting the removable neck into the receiver.    Paragraph 5 of the method of inspection in the link below relates to swivelling towbars which mine is.
http://www.ukmot.com/manual/6.6/Towbars#MOT
But on my dads F10 with the same bar as yours Matthew, the towbar is invisible when stood looking at it and depending on how observant the tech is when they are underneath it, they might not even notice the receiver!
