F10 530d
Went to BMW today to drive a 520d m sport auto to see what the difference in drive was from my 520d efficient dynamics manual. Apart from slightly harder suspension was much the same. Looks much better. But mine is a better spec. Few more extras.
Fitted my dashcam today ,10 mins to run the cam power cable and 30 mins to fit piggyback fuse and power outlet to fuse box, easypeasy!
Sent from my SM-G925F using Tapatalk
Edited by bluelights21
I must do this after buying the camera about 6 months ago. Is it wired into the cigarette lighter just? So it switched itself off when the ignition is off?
I bought mine 6 months ago too, but it's still in the box - I did make a start but couldn't reach the fuse box to install the piggyback and have up. I need a trained rat to send up behind the glove box to do it for me.
Ians100
Mount the camera where you want and run the cables back to the passenger side of the car, the cable fits under the panels quite easily. Remove the airbag switch cover at end of dash and drop end of power cable in. I then made up an earth lead and bolted it to one of the ready made holes behind the cover.
Remove the 2 screws holding the cover under the glove box at top of foot well. Remove screw that holds end of cover on tunnel.
Cover comes off with a bit of wiggling, then unplug footwell light.
Open glove box and gently prize hinge stops out so door drops right down.
Open fuse box door.
Fuse is number 54, with a light and an extra elbow, it is pretty easy to do it . Reverse for assembly. Boom! 1 dash cam installed.
Cheers, I'll have another go. Most of the pictures I've seen of the front fusebox show 54 at the bottom of the box, but on my car the FB is the other way up and 54 is right at the top :( I've just bought some extra long (400mm) long nose pliers to help get to it.
Use the fuse removal tool found in the rear fuse box in rh side of boot, it's easier to use than pliers. Yes my front fuse box is upside down. Any problems pm me.
I let my 2 cams go with the last car so I've just bought a Transcend 220 to try from mymemory. Looked new (and should have been, not graded) and the SD card in shows someone in an A3 setting the bugger up lol!
Couple of e-mails to MM to see what they are going to do as the adhesive mount is also missing (probably in the A3)
Edited by sshooie
Try these from amazon, PROtastic flat sticky Adhesive spare replacement 3m pads.
The camera is hard wired into fuse 54 with a piggyback fuse. The cig lighter goes off when the car shuts down.
Gave the car a wash and wax on new years eve, and its early days but I'm massively impressed with the finish.
Used Collinite 915, and despite reports I found it very easy to apply and buff off. The paint now feels super smooth and looks amazing! Will be repeating this procedure every 3-4 months I think. All in, the hoover inside, wash and wax took 4 hours.
Obviously it rained later that day, but I got this shot of the collinite working its magic
Must have been cold overnight, woke up to find this
