reggie59
Fuse for cigarette lighter
As Baus has noted it differs from car to car but here is a copy of the placard from my car. Seems you're looking at fuses 61 or 82 in the luggage compartment.
Horsey
post-45230-0-66445400-1430061237_thumb.j
Yours map has a nice text for each fuse. Mine has a stupid little pictogram for each fuse. Will scan and attach later. As i said, my local looked at it for 5 mns and gave up. If no one knows, i will go to bmw. They will probably try to charge me a diagnostic for £80 to tell me which fuse it is. Lol
Open boot, remove right hand side cover which covers battery. This is where the luggage compartment fuse box is located. Look at the fuse box (with a torch if need be) there will be numbers under the fuses. Pull fuse 61 and 82 out to see if they have blown. If either have replace and it should all work again.
I will check my Haynes manual later if you have no luck with the above but it should be one of those two.
Horsey
