Twiglet
4,396 posts in this topic
Today, in the ongoing hunt for the cause of crappy cold-starts and inj 1 switchoff I had the N53 apart again. Plugs out and cleaned, injectors out and cleaned, coils cleaned and checked, throttle body off and cleaned, high pressure fuel sensor replaced, would have replaced the low pressure fuel sensor too except I couldn't get the intake manifold clear sufficient to get to it.
On rebuild, all is good - clean start from cold. But that could be down to any one or combination of the actions.
The monitoring continues....
Edited by HandyAndy_UK
Cleaned it. You know it has been way too long since the last one when you are cleaning green crap out of the window rubbers :unsure:
Fitted sports button on  gear surround and fixed jammed cd changer
What's this sport button and what does it do?
It supposedly enables a hidden sports mode on car it supposed to stiffen up steering and make throttle more responsive
 Nice - never heard of that before now. Shame it appears to apply only to the petrol cars.
It's available on both diesel and petrol auto cars but it's only part of the SAT (Sports Automatic Transmission) optional extra. If your car doesn't have shift paddles on the steering wheel then you won't have the sport button.
On ‎01‎/‎03‎/‎2017 at 11:36 PM, Grizzle_E60 said:
Replaced rear plate screws, and fitted new front grills.
Love the brightness of the inner ring mate. Which bulbs have you put in it? They're the adaptive xenons right?
How come you can't see the outer ring as clear? Or is it just the way the picture's been taken?
Removed centre console:
Removed useless phone cradle:
Wired 2 12v sockets in rear:
Installed Carly A2DP Bluetooth audio device (works great):
Replaced CCC controller with CIC Controller:
Changed gear stick and handbrake gators:
Fixed front 12v socket spring.
Knackered now.
pidgeonpost, ROB163 and Westy like this
They are just these mate http://www.ebay.co.uk/itm/No-Error-H8-40W-CREE-LED-Angel-Eye-Halo-Light-Bulb-BMW-E82-E90-E92-E60-X5-X6-Z4-/201348571466?hash=item2ee14f614a:g:oFIAAOSwA3dYKsBJ
Yeh adaptive xenons, i turned the brightness up in Carly although the inner rings are a bit brighter than the outer rings.
 Thanks for the link.
Is the outer ring visible during the day? Better than how it would look if there were CREE LEDs in the halogen headlights?
with non LED's in they are visible the inner ring is still brighter though, but i just think the led and turned up makes them brighter during the day
Knackered now.
Is the cic controller a plug and play replacement other than the different mounting hole that is obviously needed
5e740658526faf35632a830b74dc29e4.jpg&key=43ddf047d839e1f597df5c304db8c82aa7e0a99c9b68e581aba2c244de402c6d
0f23c2768e7a6a1525285cc667089287.jpg&key=1e7153150c837a3711a8df1878fab8abf779e4d84dce9fb9a901623dba7ff414
e5027dcb59ca962ca3f27e5db582a144.jpg&key=bfa36919121c72b9f4f7146a09619929deb67f314cbfa7b9a1cc61236205d21b
c2a9152620173698ae14349c69efb241.jpg&key=7c628a8326ff1bb0efd8885f55def91ea298796b138d9e5a0c3fb85f0d4b038d
4ee19c232706f417392db804dfe20a47.jpg&key=fdeb1aaf240fbe0bc92736ab91f4d8c7fa3bf57b868b1ca7514fa72a9f2e19b2
2cb8d1e1ea1096ab04bd7c29f0092003.jpg&key=eb4b0c0e4f79b5d7b7c711321b2b62b33f6592b188a22d9c5790825a51ce534e
Knackered now.
Was it easy removing the center console?
No coding required.
The CCC controller has 2 plugs, one for the wheel and one for the menu button. You'll need to remove the wires going from the menu button connector and replace with pins 1,2,4,5 from the wheel connector to positions 1,2,3,4 respectively.
I have the CIC unit though, I believe the controller works with CCC too however not sure if all the individual buttons will so look this up if you're running CCC.
You'll need to buy the surround for the controller as well as the mounting frame to ensure the controller can be attached to the bezel.
David Lansley likes this
Wasn't hard, took around 2.5 hours. Got held up trying to remove a few electrical connectors which hadn't shifted since the car was built in 2005 but that's to be expected.
Followed this guide:
http://www.pelicanparts.com/techarticles/BMW-E60/76-INTERIOR-Center_Console_Replacement/76-INTERIOR-Center_Console_Replacement.htm
What are you thinking of doing with the centre console off?
6 hours ago, Medved77 said:
No coding required.
Thanks very much
sjrowe likes this
Just wanted to remove all panels to paint plus hard wire in a micro USB from cigar lighter.. Thanks
Do you have to remove the centre console to remove the telephone cradle??
You do if you want to get it out cleanly. The hinge for the cradle has a screw holding it in that can only be accessed by removing the cubby hole from the centre console. To remove the cubby hole you need to undo 3 nuts that you can only access from underneath the centre console.
I think I made a mistake though in removing the electical wires as I now have the SOS Call System Error. I'll plug those back in and if that's the issue I'll try to extract the cable from the cradle and leave them plugged in inside the console out of view.
Just passed it's MoT!
Only advisory was a for a bloody stone chip I picked up on my travels this week!
Good for another 12 months...
advisory for a stone chip??? Seriously?
