problemchild
E60 HID Fitting Guide
Mechanically secured my ballast to the middle of the crossmember and drilled a 14mm hole in the base of the cluster. You cant see any of it once fitted
image.thumb.png.25b4247bf1718ca6709988b6
Will ^ that hole in the base of the cluster remain like that or will you use something to make that moisture tight ? Guaranteed headlight condensation if it is left that way. Circular rubber grommet which comes with all hid kits provides a perfect snug fit on a 21mm hole drilled into the headlight cover.
Thanks Problemchild!
Fitted these at the weekend, unfortunately split the gromit which looks like it might be a PITA to repair, going to try a bicycle puncture repair glue and patch if the glue isn't enough, lights look spot on now although the halo's now look pants so need a cost effective plan to make then a bit close in colour!
Anthony
Hi - no probs
The grommit isn't an IP rated solution - just an attempt at stopping dust/damp in.
if yours is split I wouldn't worry too much - just make the best seal you can and if still worried stick some duck tape or bathroom sealant there :)
good luck
JJ
If anything there will be less condensation because the light will breather far more this way
Edited by kjb1
Hi Guys,
After reading here, i rang up Hid-Direct and told them what car, model, year i had and the guy on the phone adviced me that i should buy H7 35w Slim Canbus Terminator HID Kit Xenon Conversation Kit.  http://www.hids-direct.co.uk/h7-35w-slim-canbus-terminator-hid-xenon-conversion-kit/
I received it today and upon trying to see if works or not. Disappointed to say the bulb didnt come On, i also tried switching the cables around but still no luck. Is there any reason for this with Terminator Kit? Shall i send it back?
I have 2008 520d LCI model.
4 hours ago, andy-e60 said:
Short answer - send it back !
Thank you for pointing out the correct path @andy-e60 much appreciated. After reading the forum it looks like the HID kit is going to go back for straight refund.
Thanks once again :)
^ Great to know yours sailed through :).
Absolutely no reason why having aftermarket hids would ever prevent a mot pass - be it the old or new mot. Total misinformation out there regarding hids which is completely unnecessary.
Sorry to drag up a very old thread again but I found this after buying a kit from HIDS4U who I’ve used before.
I followed the guide here almost to the letter on my pre-LCI 525d M Sport touring apart from drilling holes. I don’t know the differences between pre-LCI and LCI but there is so much room in my headlamp housings that I just tucked all the components into the housing and put the cap back on!
Took maybe 20 mins to do both sides.
