Followers 0
dan101smith
M57N into 530d?
9 posts in this topic
Mechanical fitment would probably be the easiest part. How would you plan to make the newer DDE (engine ECU) work with the rest of the car (different bus structure and most of all EWS)? Some years ago I was seriously looking into this but ruled it out because of too many loose ends and variables if it would ever work. If you are going further with this idea the starting point should be last E46 330d or E53 3.0d with M57N engine.
that topic comes up even more often now. maybe we finnaly find somebody who is willing to give it a try for the rest to know :-) There is a guy called TheEnd on other forum that performed swap from m57 to m57N In e46 with all ecu coding working apparently
edit
he's on this board as well :-P
Edited by Mic_K
Followers 0
